View and Delete Debug Files
Use this procedure to view and delete debug files.
Delete debug files to free space in the internal flash. As a best practice, delete these files to ensure enough space exists in intflash. New debug files do not overwrite old debug files. You must remove the file; otherwise, enough free space might not exist in the intflash to store the core dump if the switch fails or enough space might not exist for you to transfer a new release to the intflash of the switch to upgrade your switch.
The debug-file remove command can delete the following types of files:
                core
                archive
                PMEM
                dmalloc
                flrec
                wd_stats
If you want to delete a specific file, you must use the remove command. For more information, see Fabric Engine Command References.
The following example shows how you view all debug files for all slots.
Switch>show debug-file
                                   Core Files
Directory: /intflash/coreFiles/1
1.  File:    core.logServer.20120611084204.1.tar
    Created: Mon Jun 11 08:42:04 2012
2.  File:    core.trcServer.20120611084213.1.tar
    Created: Mon Jun 11 08:42:13 2012
3.  File:    core.logServer.20120611164647.1.tar
    Created: Mon Jun 11 16:46:48 2012
4.  File:    core.trcServer.20120611164652.1.tar
    Created: Mon Jun 11 16:46:52 2012
5.  File:    core.dbgServer.20120611164700.1.tar
    Created: Mon Jun 11 16:47:01 2012
6.  File:    core.logServer.20120611164740.1.tar
    Created: Mon Jun 11 16:47:41 2012
Remote CP Directory: /intflash/coreFiles/2
1.  File:    core.coreManager.x.20120612085548.2.tar
    Created: Tue Jun 12 08:55:49 2012
2.  File:    core.coreManager.x.20120612085602.2.tar
    Created: Tue Jun 12 08:56:02 2012
3.  File:    core.coreManager.x.20120612085553.2.tar
    Created: Tue Jun 12 08:55:56 2012
4.  File:    core.coreManager.x.20120612085558.2.tar
    Created: Tue Jun 12 08:56:00 2012
                                 Archive Files
Directory: /intflash/archive/1
1.  File:    archive.20120611083021.1.tar
    Created: Mon Jun 11 08:30:22 2012
2.  File:    archive.20120611163454.1.tar
    Created: Mon Jun 11 16:34:54 2012
3.  File:    archive.20120611164354.1.tar
    Created: Mon Jun 11 16:43:55 2012
4.  File:    archive.20120611164507.1.tar
    Created: Mon Jun 11 16:45:08 2012
Remote CP Directory: /intflash//archive/2
1.  File:    archive.20120611163507.2.tar
    Created: Mon Jun 11 16:35:08 2012
2.  File:    archive.20120611164408.2.tar
    Created: Mon Jun 11 16:44:09 2012
3.  File:    archive.20120611164521.2.tar
    Created: Mon Jun 11 16:45:21 2012
Directory: /intflash/archive/4
1.  File:    archive.20120611163515.4.tar
    Created: Mon Jun 11 16:35:18 2012
2.  File:    archive.20120611164416.4.tar
    Created: Mon Jun 11 16:44:20 2012
3.  File:    archive.20120611164529.4.tar
    Created: Mon Jun 11 16:45:33 2012
Directory: /intflash/archive/SF4
1.  File:    archive.20120611163536.SF4.tar
    Created: Mon Jun 11 16:35:40 2012
2.  File:    archive.20120611164436.SF4.tar
    Created: Mon Jun 11 16:44:39 2012
3.  File:    archive.20120611164549.SF4.tar
    Created: Mon Jun 11 16:45:53 2012
                                   PMEM Files
Directory: /intflash/PMEM/4
1.  File:    pmem.20120607194023.4.bin.gz
    Created: Thu Jun  7 19:40:23 2012
                                 DMalloc Files
                                  Flrec Files
                                 WdStats Files
Directory: /intflash/wd_stats/4
1.  File:    wd_stats.log.backup
    Created: Mon Jun 11 09:25:07 2012
            The following example shows how to view only core files on the switch.
Switch#show core-files
                                   Core Files
1.  File:    core.1353113115.lifecycle.CP.1.gz
    Created: Fri Nov 16 19:45:15 2012
2.  File:    core.cbcp-main.x.20121114043335.1.tar
    Created: Wed Nov 14 04:35:36 2012
3.  File:    core.cbcp-main.x.20121114045202.1.tar
    Created: Wed Nov 14 04:54:03 2012
4.  File:    core.cbcp-main.x.20121114050825.1.tar
    Created: Wed Nov 14 05:10:26 2012
5.  File:    core.cbcp-main.x.20121114122506.1.tar
    Created: Wed Nov 14 12:27:07 2012
6.  File:    core.1353336274.lifecycle.CP.1.gz
    Created: Mon Nov 19 09:44:34 2012
7.  File:    core.1353319337.lifecycle.CP.1.gz
    Created: Mon Nov 19 05:02:17 2012
8.  File:    core.cbcp-main.x.20130122182946.1.tar
    Created: Tue Jan 22 18:32:08 2013
9.  File:    core.cbcp-main.x.20130220143809.1.tar
    Created: Wed Feb 20 14:38:10 2013
10.  File:    core.cbcp-main.x.20130225155025.1.tar
    Created: Mon Feb 25 15:50:25 2013
11.  File:    core.cbcp-main.x.20130225155407.1.tar
    Created: Mon Feb 25 15:54:07 2013
The following table defines parameters for the show core-files command.
| Variable | Value |
| {slot[-slot][,...]} | Displays the core files for the slot that you select. |
The following table defines parameters for the show debug-file command.
| Variable | Value |
| all | Displays all types of debug files |
| {slot[-slot][,...]} | Displays debug files for the slot that you select. If you do not select a slot number, the device displays all types of the archived debug files present in a slot by slot basis. If you select a slot number, the device only displays archived files for the slot you select. |
The following table defines parameters for the debug-file remove command.
| Variable | Value |
| all | Removes all types of debug files in all slots. If you use the option all with the remove debug-file command, then the device deletes all types of debug files, including the latest debug files. |
